Unecessarily repeated first time step
  • July 10, 2016
  • 0 replies
  • 841 views
A preloaded structure is the common starting point for many subsequent studies. Each subsequent study is a different loadcase.
This is driven through a design study in this case but could conceivably be a series of manually initiated studies. Using a design study the mesh remains consistent from case to case and so no re-meshing but we are able to ask Simulate to use a mesh file from disk when initiating manually.
Every analysis begins with the SAME preload calculation.
What a waste of time and CPU.
Any thoughts ?
