Units and NHA in Title block
Hello Forum,
What is the system parameter for unit that has been used in the model/drawing?
I want to use it for title block so when ever a model is introduced to the sheet, the sheet shall update the units of the dimensions.
Also the same parameter for NHA for title block
Thanks in advance,
Sanjay
KenFarley
If you did a quick search for what you're asking, you might have found the following:
Old Question about Units Parameter
which seems to indicate that there is not a units parameter associated with a model that can be queried or otherwise used for relations or drawings. A pity, but not surprising. Pretty much every company I've ever done drawings for dictates the units must be in one particular system, be it metric or english.
