User Defined Parameters?
  • April 5, 2016
  • 2 replies
  • 2820 views
What is the procedure for loading in a standard set of user-defined parameters into a part?
I've tried Tools>Parameters and then create the user defined parameters
Next: File>Save Configuration As:rp_config.xml
Next: Open New Part>Tools>Parameters>File>Load Configuration:rp_config.xml
The User Defined Parameters do not show up in the list,...just the Default Parameters?
18-Opal
April 5, 2016
Hi Jolene,
Take a look at the following article for further information on how to copy/export parameters from one part and import to another part:
CS54195 - How to copy/export parameters from one part and import to another part in Pro/ENGINEER and Creo Elements/Pro
If you are not able to access the article, please create a user account here.  The short answer is to copy & paste them.  The long answer is below:
  • Pro/ENGINEER Wildfire 5.0, Creo Elements/Pro 5.0 and Creo Parametric 1.0 - 3.0:
    • Use standard copy paste functionality
  1. Select desired parameter(s) from source model
  2. Edit > Copy or Ctrl-C to Copy
  3. Go to the target model's parameter dialog box
  4. Edit > Paste or Ctrl-V to Paste
  • While copying the parameters or parameter definitions, user can copy:
    • Multiple parameter definitions at the same time, select multiple parameters by using Ctrl or Shift
    • The user-defined parameters and user-locked parameters but not system parameters
    • Parameters from a restricted parameter table
    • Only the value of the parameters definition but not the relation argument while copying a relation-driven parameter
    • Parameters from different context, such as a feature parameter and a model parameter at the same time if viewing multiple parameters.
  • Note: If the same parameter exist in the destination part whose value is read only, Edit > Paste option will not be available for pasting the copied parameters.
Amit
Hi jkmett,
I had the same problem as you, but I was able to solve this by importing/exporting data as a .xml file instead of loading/saving the configuration. This is also in the file dropdown in the parameters window.
Best,
Ben
