User-defined parameters in assembly drawing
I've set up a parameter for part numbers and populated the values within the family table of a given component. I've then created several different assemblies that use various instances of the given component. Now I'm creating an assembly drawing and I'd like to pull the part numbers of the component into the assembly drawing in a note. Not sure how to properly set this up...I've done this in the context of a detail drawing of the component, but the assembly aspect is throwing me off.
