Using assembly parameters in family table instances
  • September 4, 2018
  • 3 replies
  • 2153 views
Dear all,
yet another parameter usage post. Hopefully not the usual. I could not find an answer to our problem.
I have a family table part and i need to use assembly level parameters into the instances. But fact is, the generic part is not used in the assembly.
it looks like - though the instances are called into the assembly and have their session ID - the generic has no session ID.
If I use the assembly level parameter in the instance relations, the relations apparently are modified at generic  level crapping up the overall assembly.
The feeling - not sure I did the right troubleshooting - is that i can not inject assembly parameters into an instance as I somewhat inject the assembly parameters into the instance. is there a way to act at instance level?
thanks in advance,
Edo777
it seems to that driving family table instances "from outside" is not implemented.
HamsterNL
18-Opal
September 14, 2018
How do you "inject" the assembly level parameters into the part?
If you are using EXECUTE statements, then this might be a solution:
  • Place the generic in your assembly. Hide it. We also use a user parameter in the family table to exclude the generic from our BOM
  • Use EXECUTE statements to drive/inject the parameters of the generic
  • Use those parameters in your instances
edo77771-VisitorAuthor
Hi HamsterNL,
thanks for your suggestion.
I have to dig down a bit myself on how to use the EXECUTE statements you propose, we never did it before here. o
And my specific project now asks me to focus on other details, so, I will let you know when I am "back-on-the-piece". Well, assembly.
Thanks for your suggestion!"
Edo
