Using existing part geometry as reference for new part
  • June 17, 2013
  • 6 replies
  • 14683 views
How does one use an existing part to design a new mating part using the already existing part as a reference? For example, if you want to design a gasket with tight tolerances for a machine with oddly placed holes.
Thank you in advance for sharing and helping this troubled engineer.
Best answer by TomD.inPDX
In the assembly, right click the component in the model tree that you want to create features for and "activate" it. While still in the assembly, you can now reference features from other components to make features in the newly active model.
Be careful, however, as you now built in dependencies to the other models you reference. I would recommend breaking those relation in the modified part at some point if this is a rare occurrence.
To re-activate the assembly, right click the assembly in the model tree and "activate".
Forgot to thank you. This really helped. Much appreciated.
Happy to help
Hi Antonius,
Need the tutorials for assmebly drawing in creo.. that includes the dimensioning, orientation of drawing etc., kindly help me with some links that contain tutorials regarding drawing in creo 2.0
Thanks & regards
Hello Dinesh. Please start a new discussion on the subject so we can keep things organized. Thank you.
thank you Mr.Antomius i made it as a separate discussion
