Using Snap Lines in drawings
  • February 7, 2017
  • 4 replies
  • 3146 views
We are using snap lines in our drawings.
What we see right in CREO 3.0 that when you create a new dimension it will not directly snap to the snap line
when you move the dimension over the snap line.
First you  have to place it, after that you can replace the dimension and than it will snap to the snap line.
I can remember that in the past it was possible to snap it directly the first time to the snap line.
Is this a config option?
Bert
I suggest you to contact PTC Support and ask them ...
MH
Yes, please do have Support file an SPR for this.
Contacted PTC for help.
I have the same problem. What is the solution for this?
Michiel
