Vanishing Imports
  • August 16, 2017
  • 8 replies
  • 2366 views
Hey,
I have been changing units from metric to English for many files I have. Most of these are files that were imported, such as pwb components. No problem with most. But a handful are giving me grief. I change the units and the import just flat out disappears. Any one have a resolve for this?
Wayne
Creo 3.0
wfalco16-PearlAuthor
Well.....just for kicks I just opened the file and did not convert anything. I supressed the import feature. Then resumed it. It has vanished!?
Have you tried to change to different model accuracy and then doing the unit conversion?  Just a shot in the dark...
No. But I may have a clue. When I try to redefine the import it points to a d:/ drive and says its a solidworks file. I feel like there is some sort of link or reference that is gone? I will try the accuracy. Thanks!
I've seen this before.  More than likely you are trying to open/import a "Creo" model that wasn't actually created by Creo.  Try using a STEP file, IGES, file, or some other neutral format.
Here is the PTC KB article saying basically the same thing:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS15712
Thanks Tom! Zooiks!
