Variable Groups
- July 24, 2012
- 2 replies
- 1117 views
We use 1760 style circular connectors often or i.e. D38999/20FJ20SN. They have twinax and coax contacts within them. I would use a variable group however the Twinax and Coax contacts within these connectors have at least two connections of their own, with only a single identifier for the contact. We typically show all the connections (Please View Attachment), which I am not sure how to approach in RSD. A variable group will give me ports per contact, but if the contact has multiple connections with a single identifier how would I address this to show all connections? i.e. with connector D38999/20FJ20SN, contact K is a Twinax contact, with two 24AWG wires connecting to it along with the Shield, or three connections for one contact. The attachment was done in Keycreator which we are migrating from to RSD.
Would it even be a variable group shape? Has anyone dealt with this type of connector?
With variable group shapes my understanding is that only one port is allowed, so would a Fixed Group Shape work? If so could you update the pins or contacts used like you can with a Variable Group Shape?
