variable pitch thread
  • March 19, 2015
  • 3 replies
  • 1264 views
How to create program for variable pitch thread, can it be created in turning itself or it requires advanced mill-turn??????????? If it is done using 4 axis surface milling i can't select surfaces to be machined as whole one so the tool follows a zigzag path how to machine these type of components???? Is there any option to do this help me please..........
We have done this using 3 axis milling. Create the curve you want to follow then use trajectory to follow the curve.
shaanmech1-VisitorAuthor
thank you Mr.Bill Chapman i will try using trajectory soon i will back to you..........
