Warp "Sculpt"
  • October 4, 2011
  • 7 replies
  • 3661 views
i am trying to rough up an area of a flat surface, give it texture so to speak, (a ripple effect). I have projected a kind of cloud shape on to my flat surface & now i want to have the surface within this boundary have texture, no more than 1mm deep. I have been trying to achieve the desired result using the warp, sculpt tool but find it difficult to work with, i can get half way there with it, but its not quite want i want to see. The main problem is the boundary shape, it is difficult to stay within it. I pick the projected curve as a reference & this helps resize the sculpt grid, but no matter what i do, i end up deforming the flat surface outside my boundary. It would help if the grid could be set to a finer increment, it only allows 20 rows by 20 columns max. I am using WF5, standard license.
The rough surface needs to be physically present, i would machine from it ultimately, so using the appearance manager to render the surface cosmetically would be useless. Any ideas, anyone?
Regards
John
Hi John...
I think this might be a good situation for a surface replacement. You can both add and remove material at the same time using this technique. You'd make a surface representing the ripples. Then, you'd trim the surface to the shape of your cloud. Finally, you'd patch this quilt into your solid to complete the effect. This should give you very precise control of the ripples, shape, location, and transition area.
If this sounds like what you're after, let me know. You can either research it yourself through the help files or I can put together a brief tutorial demonstrating the technique.
Thanks!
-Brian
Hi Brian,
what you describe certainly sounds interesting. If you could spare the time, i would take you up on your offer of a brief tutorial for sure, anything that could help me along with this project would be greatly appreciated.
Regards
John
Okay... I'll try to whip up something... slides or a video. I'll only be able to demonstrate a small portion of the potential solutions. I can think of several. I'll try to get you pointed in the right direction. I'll need a day to create the tutorial. Hang tight and I'll get back to you!
Thanks...
-Brian
