Weight of Shrink Wrapped Part
How do I assign a weight to a shrink wrapped part with no weight?
tbraxton
tbraxtonAnswer
If you only are concerned with the weight then create a solid sphere or cube inside the surface boundary of an arbitrary volume (i.e. 1 in^3). You can then assign the density in the part such that the volume of the solid feature multiplied by the density is equal to 2 pounds. Creo will then calculate the mass properties and the weight will be 2 Lbf.
tbraxton
tbraxton
I should have noted that you can use relations to control the assigned mass to the shrinkwrap part by using the mass property calculations of the parent model of the shrinkwrap such that it will always be accurate and current upon full regeneration. This way you will have accurate mass properties in any models using the shrinkwrap part(s).
wfalco16-PearlAuthor
Thanks! I hear what your saying about the relation to the model. I created a shrink wrap part independent of the model. It is a power supply with too much detail. No real need to update. I would like to assign a weight somehow. If it's relations, can you give me an example?
StephenW
I've done this several ways in the past.
If the shrinkwrap model has solid geometry, I will adjust the density of the shrinkwrap so that it matches the weight needed.
If the model is a surface model AND I am concerned about CG location, I will add a small sphere at the CG location and adjust the diameter/density to match the desired weight.
If you want to simply assign the weight, you can go to File - prepare - mass properties change and set the "define by" to assigned.
The shrink wrap is all surfaces.
tbraxton
tbraxton22-Sapphire IIAnswer
