WF4.0 Feature Recognition Tool install
  • December 9, 2010
  • 3 replies
  • 1032 views
I am looking for some help with installing the Feature Recognition tool with WF4 M150. I downloaded the program from PTC and followed the instructions. When I startup pro I keep getting the following error message: feat_recgn_dll failed to start.
Thanks in advance
DomenicLaritz
Let us assume, the install directory of the Feature Recongnition Tool is "C:\FRT".
This directory has 2 subfolders, "bin" and "text", and the 2 files "frt.dat" and "config.win". The directory "bin" also has two subfolders, "i486_nt" (contains the 32 bit DLL "pt_feat_recgn.dll") and "x86e_win64" (contains the 64 bit DLL with the SAME name "pt_feat_recgn.dll").
Now edit the file frt.dat:
exec_file C:\FRT\bin\$PRO_MACHINE_TYPE\pt_feat_recgn.dll
text_dir C:\FRT\text
As last step, add the line (without quotes) "protkdat C:\FRT\frt.dat" to your config.pro file and it should work.
P.S.: The variable $PRO_MACHINE_TYPE in the path of the file frt.dat should ensure that if you start a 32 bit Pro/E, the 32 bit DLL gets used and if you start a 64 bit Pro/E, the 64 bit DLL gets used.
Regards, Domenic
Ok, it's been a while and I only did this once (disclaimer) but I think
this is the issue.
In your config.pro file you should have a line that looks like this
toolkit_registry_file C:\Program Files (x86)\proeWildfire
4.0\frt_wf4_m060_47.01_win64\frt.dat
Also, you should have a folder in your Pro/E loadpoint
C:\Program Files (x86)\proeWildfire 4.0\frt_wf4_m060_47.01_win64
the frt.dat file in this folder should be edited to set the path
ours looks like this
#Feature Recognition Tool Version :: 47.01
name feat_recgn_dll
startup dll
exec_file C:\Program Files (x86)\proeWildfire
4.0\frt_wf4_m060_47.01_win64\pt_feat_recgn.dll
text_dir C:\Program Files (x86)\proeWildfire
4.0\frt_wf4_m060_47.01_win64\text
allow_stop true
delay_start false
end
Hope this helps
Bob Frindt
Sr. Designer
Parker Hannifin Corporation
Parker Aerospace
Gas Turbine Fuel Systems Division
8940 Tyler Boulevard
Mentor, OH 44060 USA
direct (440) 266-2359
JoeFrancz1-VisitorAuthor
Ok I found the problem. First of all want to that everyone that sent me suggestions. After further investigation I found that I had the 32 bit of pro/e installed and not the 64 bit. I was trying to install the FRT for the 64bit version of pro on a 32 bit install.
Solution: Installed the 64 bit of pro and everything works great.
Again thanks for all the supplied their input.
