6-Contributor
January 15, 2010
WF5_M020 - PDF export
  • January 15, 2010
  • 10 replies
  • 5267 views
Hello, PTC solved problem with small axes and thickness of text in pdf files, but new pdf files have 3x - 5x more kB. It look like that some compression algoritm missing.
JerseyC6-ContributorAuthor
6-Contributor
January 19, 2010
Another problem, generated pdf files have no same administration rules as upper directory. It mean I can´t copy and open files through ethernet.
The PDF files does not get any bigger in size for me using WF5 M020. Have you checked Settings for PDF so that you don't use the highest Resolution? Within Settings it's also possible to change Security settings.
6-Contributor
January 19, 2010
Hello Magnus, Resolution is still the same 300 dpi and nothing marked in security book-mark.
