WF5 or Creo Elements/Pro
  • March 17, 2011
  • 22 replies
  • 6311 views
Hey everyone,
Got a quick question or 2...
I am in the process of upgrading from WF4 to either WF5 or Creo Elements
which I believe is similar to WF5, if not the same altogether.
My question is should I skip over WF5 and step right to Creo
Elements/Pro or is Creo still more or less in the testing phase?
Some details that I am curious about are:
* Doe the interface/environment look exactly to same from WF5 to
Creo?
* Do all the Mapkeys/configs that worked in WF5 automatically
work in Creo?
* Is WF5 soon going to go away and be replaced by Creo?
* Are there any advantages or disadvantages to going right into
Creo Elements/Pro?
* Will Creo Elements work fine with EMX6.0?
Paul
Paul Mailloux
Cad/Cam Applications Engineer
NyproMold Inc
144 Pleasant Street
Clinton MA 01510
Phone: (978) 368 - 4598
Fax: (978) 365 - 4548
www.NyproMold.com
I still never use a folder with a space in the name for any PTC product install!
My PTC install loadpoint is always <drive>:\PTC\<product_version>. Example: P:\PTC\Proewf4_m150-x64 or P:\PTC\Proewf4_m150.
IT has installed some builds to the default Program Files folders and they do work, but I still prefer the 'no space in folder name' folders.
Thank you,
Ben H. Loosli
USEC, INC.
Played with the install and changed the name to not have spaces in as all
my scripts broke and had to have quotes round all calls from cmd prompt
Best Regards
Chris Collinson
CAD Administrator
I'll second that !
You're the new guy, right? (lol)
The new guy? Been on Pro-e since version 7, yeah right new guy 🙂
Sent via BlackBerry by AT&T
NYUK! NYUK! NYUK!! Tanks... I needed a good laugh... must be Friday!
Thanks...
Paul Korenkiewicz
FEV, Inc.
4554 Glenmeade
Auburn Hills, MI., 48326
Dad? Is that you? 😉
Tim P. Cooper
LM IS&GS-CIVIL, Houston
ITL Facility and Mockups Design
LM2 / Cube 228L
Physical Address: Correspondence:
2400 NASA Pkwy LM2, 228L
Houston, TX 77058 P.O. Box 58487
(281) 333-6735 Houston, TX 77258-8784
(281) 333-???? (F)
@Tim... ROFL...
@Nathan.... For not being the new guy, you should know by now then....
"That is the problem with PTC software. They leave the debugging to their customers as a means of reducing their internal costs."
I'm one of themorons that waste a lot of time submitting bug fixes to PTC... the worst part is that they do not fix them... so I don't know why I keep doing it... as I said, I'm naive a moron...
Thank you,
Daniel Santos - CAM Support
GE Oil&Gas
Being Friday and all, isn't that one of the definitions of insanity? Doing the same thing over and over, but expecting different results?
Jeff Horacek
Sr. Designer
[cid:image001.jpg@01CBE583.34804890]
STERIS Corporation
5960 Heisley Rd.
Mentor, OH 44060
(440)392-7721 P
(440)392-8954 F
