what is internal geometry error?
what is internal geometry error? and how to bypass it? trying to unite parts.
Hi, can you specify a little bit more
Whitch program and version do you use?
You are here in the Creo Elements/Direct forum.also referred as "Direct Modeling"
Helpfull should be the upload of the file with the problem.
Best regards
Friedhelm
