3-Newcomer
when applying a distance constraint, the dimension was given in mm and is not translated to drawing
when applying a distance constraint, the dimension was given in mm and is not translated to drawing properly, it was entered as 1mm on the assembly, more like 20mm is actual constraint. have i the wrong template, i may have started with the wrong template
Emeritus
Hi @PG_11980159,
Thank you for your question.
Your post has not yet received a response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Vivek N
Community Moderation Team.
