3-Newcomer
Dec 9, 2024 2:17 AM UTC
when applying a distance constraint, the dimension was given in mm and is not translated to drawing
when applying a distance constraint, the dimension was given in mm and is not translated to drawing properly, it was entered as 1mm on the assembly, more like 20mm is actual constraint. have i the wrong template, i may have started with the wrong template
Emeritus
Dec 13, 2024 3:43 AM UTC
Hi @PG_11980159,
Thank you for your question.
Your post has not yet received a response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Vivek N
Community Moderation Team.
