where is the Shaft feature in Creo 2.0
  • September 16, 2014
  • 9 replies
  • 4074 views
Insert > Advanced > Shaft in ProE Wildfire 5 for the On Point placement option.
I wonder where it is in Creo 2.0
Best answer by GabrielZaha
It's not in the ribbon. You need to customize the ribbon (look under "Commands Not in the Ribbon") or to use the command search tool
jzhang-31-VisitorAuthor
OK, I found Shaft by seach. Thank you very much!
Hi Jack, can you please brief what this SHAFT command does?
https://www.youtube.com/watch?v=VNES-Cplu4Y
this are available when u activate anatomic features
