Which API is best suited for dimensions?
  • August 18, 2016
  • 0 replies
  • 724 views
Folks
I get complaints to convert MMC dimensions into Nominal. So which API will automate the conversion of parts dimensions into Nom, MMC, LMC. As long as the dim has tolerance,  I like the minimum input from the user. or maybe ask whether is cut or protrusion, or just looking at the tolerances will tell you if the feature is at MMC or LMC.
