Which element(s) to look for when extracting an image snapshot from a .prt file?
Hi all,
I am trying to extract an image snapshot from a Pro/Engineer (.prt) file for the purpose of displaying. The underlying goal is to enable people to quickly pinpoint design files of interest in deep archives containing design files of all sorts (Pro/Engineer, SolidWorks, AutoCAD, ...). By showing the thumbnail images, people presumably should be able to quickly relate to the search hits and develop a sense as to whether a particular search hit is of interest or not.
Questions
1. What format does Pro/Engineer use internally for the .prt files?
--> [ I understand that SolidWorks uses the structured storage mechanism from Microsoft for the .SLDPRT files. ]
2. Where can I find information on the names and roles of the associated elements (at least the ones related to 2D image representation)?
--> [ I know PreviewPNG represents the corresponding element in the SolidWorks (.SLDPRT) files. ]
Best regards,
Baldur
P.S. I apologize if this forum is not the most appropriate one for my questions. I have been looking around online quite a bit for material on the internal data format, about the availability of a SDK (API) to Pro/Engineer, contacts for the technical support, etc. I have been able to locate a lot of material, most of which has not been meaningful to the questions above.
