WHY!!!!!!!
  • February 11, 2016
  • 1453 views
I hope someone from R&D reads this post because there are things that missed the mark in 3.0 that need to be changed in the following iterations. Nice try Creo team but why do I have to click 15 times on my title block to enter parameter driven information??? No reason at all. Serious waste of time. If youre not paying close attention its easier to overwrite the parameter than it is to enter the driven information. Terrible change please get rid of this Im losing what marbles I have left working through drawings.
This isnt the only issue...
StephenW
Look at Creo 3 drawing - strange updating parameter value in table.
There is a specific workaround for this but not really a solution.
jmay1-VisitorAuthor
Thank you for the response.  I will add that the workaround is using the right click which still requires more mouse travel than I would like and I found that an additional workaround is to customize the right click menu by going to file....options....shortcut menu...and then reorganizing as you see fit to cut down travel.
