Wildfire 3.0 M250's PDF Publisher not working in Win7
  • September 13, 2011
  • 2 replies
  • 2119 views
PTC does not support 3.0 when used with Win7 so I'm hoping someone here can help. Has anyone else had issues with the PDF
Publisher not working in Win7?
S Pfahler
Do you have the 64bit Windows 7? I have noticed that PDF is not available in WF3 in 64bit but is in 32bit. I have found that I have to work on the drawing then switch to a 32 bit system to create the PDF. It was this way on all the releases of WF3 that I tried.
I have not had a problem with PDF publishing in Win7 32bit.
I think it is possible to install and use ProE WF3 32-bit in Windows 7 64-bit.
Martin Hanak
