Windchill PTC names & file parameters
  • August 22, 2017
  • 8 replies
  • 4228 views
Creoites:
I've seen a similar thread to what I am about to ask, but don't think I saw a finite answer.
Is anyone relating the 3 Windchill filenames to parameters in the files? This way it is written only once.
The way I see it, seems like the parameter can't control the PTC name - since this involves renaming in Windchill.
But it would seem do-able to have the PTC names report to the parameters in the files. Only negative there for us - is we use title_1 & title_2.
Bottom line is - anyone implementing something like this?
WayneF
I've debated about using the Windchill Name (Creo Common Name) parameter to either replace or drive our Creo DESCRIPTION parameter.
Pros:
  • Being able to rename your CAD or drawings Title/Description from Windchill
  • Not having to create Windchill Views everywhere for your company's DESCRIPTION parameter
Cons:
  • The entire history of the object will get changed during a Windchill Rename for the Windchill Name, Number, and File Name - aka you can change your drawing history especially if you use Windchill PDF publishing. The Windchill DESCRIPTION (if designated from Creo and driven by a relation from Creo Common Name) will likely NOT change during a rename even though autopublished PDFs and Creo will have the new DESCRIPTION since changing Windchill parameters usually requires a check in.
  • Having users convert drawings over time to the new standard. Unless you can use ModelCheck or something similar, you'll likely get some CAD converted when users make changes and some not.
  • Having to train users to use Creo/Windchill Rename commands any time they would want to change the title/description of an object.
  • Having to train users not to use the same part number for Windchill Name, File Name, and Number (we currently have them use the same for all values).
I'm in the camp where these CONs outweigh the Pros. I'd be currious on other people's thought on this though.
Side note: it seems like people use multiple title/description parameters (TITLE_1 and TITLE_2) to be able to show parameter on multiple lines in a drawing title block. Creo Drawing Tables have a 'Wrap Text' text setting that can allow a single parameter to wrap accross multiple lines.
Same here.  We may use Name (Common Name) for a generic description in the future (almost like classification), but our separate DESCRIPTION parameter is way to specific and version dependent to tie directly to the global value of Name.
