Window switching crash problem (窗口切换崩溃问题)
  • November 26, 2021
  • 864 views
I am using Creo Parametric - Release 3.0 (connected) 3.0 M190
In the model tree in the lower left corner of the engineering drawing, opening the model, and then clicking the drawing window from the model to switch back to the drawing interface will crash. What are the reasons for this kind of problem?
Translated with Google Translate
Translated by Hedy Jin, Nov 26th, 2021
在工程图中的左下角模型树,打开模型,再从模型点击工程图窗口切换回工程图界面会崩溃,请问这种问题一般是由哪些原因引起的?
Read the following articles:
Also there was a similar question earlier - "Crashing! Creo 3.0": https://community.ptc.com/t5/System-Administration/Crashing-Creo-3-0/td-p/476042
