Word wrap for string parameters in drawing tables
  • May 16, 2012
  • 2 replies
  • 1307 views
When entering string paramenters into tables, the tables can become cumbersome when the string parameter is of significant length.  A way to wrap a parameter, either by a set number of characters, or by a column width would be valuable.
Add into this request to also remove the 80 character barrier that exists for all parameters.  There shouldn't be a reason that Creo has a length limitation when PDMLink has the ability to pass much longer pieces of text to Creo.
Text wrapping of string parameter values when the parameters are called out in table cells is supported in Creo 1.0 and later. Just select the table cell and then right-click > Wrap Text.
