Yellow Traffic Light with a drawing
  • July 12, 2016
  • 4 replies
  • 4911 views
I had a user ask me why they can get the drawing to obtain a "green" status light.  They have a "yellow" status light.  The assembly model if completed solid with a "green" status light.  Any suggestions on how to see what is going on in the drawing?
Joe
FIrst thing to check is if they have more than just 'the assembly model' that they are thinking of.  Look to the model tree, and pick the model pulldown, and look through the models.  Are any models (or any particular simp reps of the models) yellow?
Go to drawing environment
click on the set the active model/rep icon drop down menu......in that some of the file may in yellow light, click on that file and regenerate the same.
you will get green light.
even tho model is fully regenerated .....some times we call other model (out of this assembly) to place in drawing .....if that models are not regenerate fully , then you will face this kind of issue.
I hope you are problem is solved.
JoeFrancz1-VisitorAuthor
Thanks for the info.  That worked perfectly
2-Explorer
July 19, 2016
Hello Joe Francz
mark correct asnwer if your question has been solved. It can help others in future .
