Creo 2 - merging curves
Anyone have suggestions for merging sketched curves in Creo 2 Parametric? Weve done this on a fairly regular basis in Wildfire 4, but now the instructions in Creo state "Click Restyle > Combine, select a curve, select another curve" When I choose Restyle, it tells me I don't have a license for that function. Is there another way to merge curves?
Erik
egiffordAnswer
Found the answer on the ptcuser board - Composite Curves is what it's called. Go here for the how to - actually very simple.
Erik
Look at datum reference and its intent curve or intent chain type.
The only other place I know that merge curves exist is the import data doctor.
egifford12-AmethystAuthorAnswer
Erik
It seems like PTC is hiding this feature although it works as described in Creo (using Ctrl C and Crtl V) but makes a copy feature.
I don't see any commands that create a composite curve.
However, the Reference datum Intent Curve option does the same thing.
