3-Newcomer
April 24, 2026
Creo Simulate: Run complete with fatal error
  • April 24, 2026
  • 2 replies
  • 128 views
I am trying to simulate a press-fit snap feature for validation, however when I run the simulation I get the error “Run completed with fatal error”.
Following parameters are set:
Mesh:
  • Component-component interface (contact), assumed 0 friction (also attempted surface-surface contact with 0.2 COF)
  • Mesh on both parts with 1mm localized elements on snap-features (tetrahedral)
Constraints:
  • Prescribed 3mm movement in +Z direction on Part A (to push part A onto part B), fixed in X and Y direction
  • Part B constrained in XYZ direction
Material Assignments:
  • “Part A” Full-hard stainless steel
  • “Part B” Xantar 22R (PC)
Analysis Settings:
Section view of snap fit
Can anyone assist?
Many thanks.
Articles:
18-Opal
April 27, 2026
If you have not ran this type of analysis before on the machine - check your graphic card compatibility.
