6.0 m010 upgrade: some generated tables not breaking
Still trying to chase down differences between those that do, those that
don't, but was wondering in advance if anyone saw/fixed tables, generated
or otherwise, that broke just fine before an upgrade to 6.0.
Paul Nagai
    naglists1-VisitorAuthor
    FOSI, by the by.
    We upgraded from 5.2 to 6.0 and we noticed that some tables used to begin near the bottom of a page in 5.2 and only show a row or two at the bottom of that page. In 6.0 they now begin on the next page.
    I have seen a little of that, too. Not chasing that one yet.
    something about my generated table theads are upsetting 6.0.
    I updated my e-i-c for entry to include the rotate support.
    <entry rotate="1">
    1 = 90 degrees
    2, 180
    3, 270
    Which lets me remove some tex hacks in the generated table headers.
    I am still testing, but it looks like in the thead e-i-c
    is not working. Weird.
    I'm also losing the bottom rule on the not-last page of a table that
    breaks. (I'm sure there is better English to describe that.)
    I know some folks think that's proper (and I like the cue it provides) but
    I'm pretty sure my authors, at least some of them, aren't going to like it.
    Hi Paul,
    I haven't noticed any differences with our table breaks, we've just started our 6.0 regression testing. We are using FOSI so I'll let you know if I see anything like that.
    I may have some insight to your not-last-page-bottom-rule table issue (I think I used worse english than you to describe it). We use the following definitions in a custom.tmx file in the custom\inputs folder:
    \TableSplitPreBrk=0 % -1=none, 0=solid, 1=dotted, 2=dashed
    \TableSplitPostBrk=0 % -1=none, 0=solid, 1=dotted, 2=dashed
    \TableRulePreBrk=1 % 0=none, 1=previous row rule, 2=first table rule
    \TableRulePostBrk=1 % 0=none, 1=previous row rule, 2=first table rule
    Everything after the % in each line is a comment (so I can remember which value means what). Those definitions preventour tables from having that "empty bottom" when they break across a page. This is workingin our 6.0 environment (worked in 5.3 and 5.4 for us as well).
    Hope that helps.
    -Brett
    In Reply to Paul Nagai:
    Thanks, Brett. I've got a .tmx file that does something fun but I don't
    remember what that we've been dragging around for several versions. I'll
    give those a whirl.
    On Thu, Jul 19, 2012 at 7:51 AM, Brett McCorkle <
    brett.mccorkle@erieinsurance.com> wrote:
    > Hi Paul,
    > value means what). Those definitions prevent our tables from having that
    > "empty bottom" when they break across a page. This is working in our 6.0
    > Hope that helps.
    > -Brett
