Mar 7, 2011 7:21 AM UTC
Arbortext And Windchill.
Hi All,
I am pretty new to Arbortext. I am not getting a fair idea about
following,
1.How we can use Arbortext for generating manuals by taking data from
Windchill?
2.What is Bursting? Could you Please let me know what this term exactly
means? How this is achieved in using Arbortext and Windchill?
3.What are the guides I need to refer to achieve this functionality?
Thanks in Advance for your Time,
Manisha
    Mar 7, 2011 7:35 AM UTC
    Hi Manisha,
    Welcome to the world of Arbortext J
    1. You mean you want to import PDM data or CAD drawings into your content?
    Or you want to use Windchill as an XML content repository?
    2. Bursting is the process by which compound documents are managed by
    Windchill. For example, you may have a user's manual composed of 10 sections
    and an appendix. It is often preferable to store the user's manual as 12
    separate objects in the CMS (the "book", the 10 sections and the appendix).
    The process by which Windchill manages this is bursting. Bursting is
    configurable dependant on the doctypes you are using (eg. Docbook vs DITA vs
    custom).
    Bursting happens automatically, once you have set everything up.
    3. I believe PTC has quite a lot of online training material on these topics
    (a 12 month PTCU subscription is available at a very reasonable cost). There
    are also quite a few manuals and the Help Center which ship with the
    software. These will be your best starting point.
    If you are staring down the barrel of a significant Windchill+Arbortext
    implementation, with many customisations required, it may be best to engage
    the services of a specialist Arbortext consultancy. representatives of which
    you will find lurking around this very mailing list J
    Hope that helps.
    Cheers,
    Gareth
    Mar 7, 2011 7:47 AM UTC
    Hi Gareth,
    Thanks for the Information!!
    I want to import CAD drawings and images from windchill.
    For using windchill as xml content repository, First I need to generate
    that XML, Am I right? If I need to generate the XML, will it require
    customization?
    Manisha
    Gareth Oakes <goakes@gpslsolutions.com>
    03/07/2011 12:05 PM
    Please respond to
    To
    cc
    Subject
    [adepters] - RE: Arbortext And Windchill.
    Hi Manisha,
    sections and an appendix. It is often preferable to store the user's
    manual as 12 separate objects in the CMS (the "book", the 10 sections and
    the appendix). The process by which Windchill manages this is bursting.
    Bursting is configurable dependant on the doctypes you are using (eg.
    Docbook vs DITA vs custom).
    Bursting happens automatically, once you have set everything up…
    topics (a 12 month PTCU subscription is available at a very reasonable
    cost). There are also quite a few manuals and the Help Center which ship
    with the software. These will be your best starting point.
    engage the services of a specialist Arbortext consultancy… representatives
    of which you will find lurking around this very mailing list J
    Hope that helps.
    Cheers,
    Gareth
    Mar 7, 2011 1:15 PM UTC
    Hi Manisha,
    I'm a little out of my comfort zone now, but I believe the more professional technical manuals are created by using the IsoDraw tool to turn the CAD models into illustrations.
    For using CAD renditions directly I think you need to use WVS (Windchill Visualization Services) to ensure that the CAD objects have a suitable representation attached to them. This may involve installing some Windchill plugins for handling the CAD models if you don't have the plugins installed already. Anyway, once you have WVS generating representations for the CAD models you can then insert the representations (eg. JPEG, TIFF, EPS) into your technical manual using Arbortext Editor, via the built-in Object Browser.
    BTW, yes, your technical manuals will need you to author in XML. You should really check out some of the introductory courses in the PTC training material to help get your head around it all.
    Cheers,
    Gareth
    Mar 7, 2011 2:21 PM UTC
    Hi Gareth,
    Thanks a lot!!
    I will check for the courses available and come back If having more
    questions.
    Thanks & Regards,
    Manisha
    03/07/2011 05:45 PM
    Please respond to
    To
    cc
    Subject
    Hi Manisha,
    Cheers,
    Gareth
    Mar 8, 2011 8:34 AM UTC
    Hi All,
    Could you all Please let me know where is burst configuration file where
    I can define rules for bursting a document?
    Thanks & Regards,
    Manisha
    03/07/2011 05:45 PM
    Please respond to
    To
    cc
    Subject
    Hi Manisha,
    Cheers,
    Gareth
    Mar 8, 2011 8:50 AM UTC
    Manisha,
    You may want to have a look at the Arbortext Help Center, which is available both online at http://www.ptc.com/cs/help/arbortext_hc/ae54m080_hc/ and offline on the PC where Arbortext Editor has been installed.
    The Help Center (published with Arbortext itself) is a comprehensive source of information in which you can find answers to most of your questions.
    Bursting rules are documented in the Content Management Guide, which is located under Administration / Arbortext Editor…
    There you can find the topics called “PTC Server Connection Setup” and “PTC Server Connection Document Bursting”
    Alessio Marchetti
    PTC.com <">http://www.ptc.com>
    From: Manisha S Pawar [mailto:manisha_s_pawar@whirlpool.com]
    Sent: martedì 8 marzo 2011 8:34
    To: -
    Subject: [adepters] - RE: Arbortext And Windchill.
    Hi All,
    Could you all Please let me know where is burst configuration file where I can define rules for bursting a document?
    Thanks & Regards,
    Manisha
    03/07/2011 05:45 PM
    Please respond to
    To
    cc
    Subject
    Hi Manisha,
    Cheers,
    Gareth
