Jun 13, 2024 11:01 AM UTC
Can't insert figgroup element
I'm trying to insert the figgroup element as shown here:
However, it is unavailable as markup to insert:
I am able to locate it in the stylesheet:
Any help would be greatly appreciated.
Jeff
bfriesen
bfriesenAnswer
18-Opal
Jun 13, 2024 2:55 PM UTC
My guess is yes you will need to reach out to the consultants for them to check what has changed that is not allowing the figgroup to not show up. If it is not throwing errors about the element, that means it is still valid in the context.
Bryon
bfriesen
18-Opal
Jun 13, 2024 12:59 PM UTC
If you search the online knowledge base, the last time anything figgroup was mentioned was in the servicemanual application documentation for editor 6.1 F000.
Hidden Elements and Attributes
The following elements are included in the DITA document types, but are not
intended to be used for authoring. By default, these elements are not displayed in
the PTC Arbortext Editor Insert Markup and Quick Tags features.
• boolean
• data
The data element is not hidden when the cursor is in the topicmeta
element in a DITA map, the prolog element in a DITA topic, or in a
specialization based on either of those elements.
• data-about
• figgroup
• foreign
• index-base
• indextermref
• itemgroup
• required-cleanup
• topicset
• topicsetref
• unknown
Bryon
JSkog12-AmethystAuthor
Jun 13, 2024 2:41 PM UTC
Hi Bryon,
Regarding this excerpt from our stylesheet requirements (per our PTC consultant):
Do we need to contact our consultant regarding the implementation of this specialization?
Jeff
bfriesen
bfriesen18-OpalAnswer
18-Opal
Bryon
