bfriesen
18-Opal
Apr 15, 2013 4:53 PM UTC
finding generated text in footer (newbee)
We have a customized stylesheet. I am trying to find out where the generated text is coming from in the footer. I need to remove the word part#. How do I tell what tab I need to look at. Is it an element, property set..?
    18-Opal
    Apr 15, 2013 5:06 PM UTC
    Hi Bryon--
    It depends which version of Styler you're using, but if you are using
    6.0, it is probably defined as a Generated Content object. These are
    listed on the sixth tab over (icon is some lines of text with a red
    dotted rectangle around them). There may be more than one generated
    content section you need to modify, if different page types use
    different footer content (for example, odd pages vs. even pages).
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    1380 Forest Park Circle, Suite 100
    Lafayette, CO 80027
    bfriesen
    bfriesen18-OpalAuthor
    18-Opal
    Apr 17, 2013 5:23 PM UTC
    I found the part# ref and went through every page and removed it from instance where I found it. My problem is it still shows up on my TOC. How do I find out where the TOC page is being generated from. I did modify contents pages, but it does not seem to correct my issue.
    Bryon
    Apr 17, 2013 5:34 PM UTC
    TOC entries (at least the ones created by FOSI) are supposed to be linked to the source. So if your cursor turns into a pointing finger when you mouse over the TOC entry, you should be able to double-click it and go to whatever is crating that TOC entry.
    If you are not using FOSI, then this response will probably not be useful.
    Apr 18, 2013 8:37 PM UTC
    Hi Bryan,
    To find the generated text for a ToC page, you can follow the
    trail from the Table of Contents page set (on the Page Sets tab),
    then look at the Page Types tab at the bottom to see what pages
    are being used. You can then click the "Go To" buttons to jump to
    each page. Then on the Page, you find the page region you're
    interested in (the footer I think), and again click "Go To"
    to go to the Page Region in question.
    Finally, on the Text Tab of the Page Region, you can jump to
    the Generated Text (another "Go To" button), and there you can
    edit it to take out the part #.
    Richard
    Apr 18, 2013 8:51 PM UTC
    Oh Sorry - meant "Bryon" of course! 🙂
    bfriesen
    18-Opal
    Apr 19, 2013 1:21 PM UTC
    Thank you all for the responses, I have found the text entries and have removed them.
