May 25, 2011 4:01 PM UTC
FlexLM bug - multiple interfaces
It seems that if you have a fixed license, multiple interfaces on your
computer (Wired and Wireless), and you switch between them, the FlexLM will
tell you that your software isn't licensed and it won't open. Your license
file is tied to one interface --- that must be "top priority" (active) in
order for your license file to authorize use of the software.
PTC has a work around that requires you to go into the registry and monkey
around forcing one of the interfaces to always be "top priority", rather
than getting Acresso to fix the bug in FlexLM. It should be querying all the
interfaces on the machine, not just the "top priorty" one.
FYI,
Liz
    May 25, 2011 4:25 PM UTC
    I heard about that in Orlando ... bummer it hasn't been addressed.
    On Wed, May 25, 2011 at 9:01 AM, Liz Fraley
    > FYI,
    > Liz
    lfraley1-VisitorAuthor
    May 25, 2011 6:03 PM UTC
    Apparently if we want this changed, we all need enhancement request.
    May 25, 2011 6:06 PM UTC
    s/need/need to file/
    On Wed, May 25, 2011 at 11:03 AM, Liz Fraley <liz.fraley@single-sourcing.com<br/>> wrote:
