FOSI and Table Properties?
  • September 27, 2010
  • 16 replies
  • 8949 views
This relates to my previous post on table formatting. I've got a new
problem where I'm trying to format the header row of a table. I want to
set the text to center justify. Setting this in the FOSI doesn't change
the output even though the "resolve" display shows it as center.
When I select the row with Table Properties, it seems like Left justify
might be the default - Left is what I'm finding as my output.
For table width, PTC indicates that having a full width table is the as
designed intention when columns are set proportionally. Setting the Table
Property of Use Default (100%) seems to have no effect.
Setting the columns to fixed values makes the table set to less than full
page width. I thought that maybe center justification needed a fixed
width, but that didn't change anything.
Any idea why my headings will not center justify?
..dan
    Definitely believe we could answer better if you included a chunk of tagged data and the FOSI <e-i-c>(s) involved.
    Steve Thompson
    +1(316)977-0515
    Dan,
    This "Use Default (100%)" on this screen shot is ONLY for display in the editor window and has nothing to do with output margins.
    [cid:image001.png@01CB5E54.49DBB370]
    If some columns must be fixed width, set the widest column to "Proportional" and Arbortext will make the column whatever width it needs to be to make the table fill between the margins.
    The table usually is less of a pain if all columns are set to "proportional".
    [cid:image002.png@01CB5E54.49DBB370]
    Most of the crappy formatting I see in tables is where the author accidentally changes the row depth, so I select all rows and set the row height to "natural".
    [cid:image003.png@01CB5E55.B3330ED0]
    Instead of trying to set justification on ROW elements set it on the entry element (called CELL in this screen shot):
    Set horizontal justification to CENTER on the cells you want centered (usually only the header row(s)).
    [cid:image004.png@01CB5E55.B3330ED0]
    I hope this helps and is not answering a question you didn't ask.
    -Andy
    \ / Andy Esslinger LM Aero Tech Order Data
    _____-/\-_____ (817) 279-0442 1 Lockheed Blvd MZ 4285
    \_\/_/ (817) 777-3047 Fort Worth, TX 76108
    Thanks, Andy...I just copied that into the writer's training folder! As far as Dan goes, well...he's on his own.
    John T. Jarrett CDT
    Senior Tech Writer, Integrated Logistics Support, Land & Armaments/Global Tactical Systems
    T 832.673.2147 | M 832.363.7234 | F 832.673.2376 | x1147 | -<">mailto:->
    BAE Systems, 5000 I-10 West, Sealy, Texas USA 77474
    www.baesystems.com
    Data
    <table>
    <tgroup cols="3">
    <colspec colname="col1" colwidth="61.73pt"/">
    <colspec colname="col2" colwidth="137.77pt"/">
    <colspec colname="col3" colwidth="124.21pt"/">
    <thead>
    <row>
    <entry valign="top">Light</entry>
    <entry valign="top">Indicates</entry>
    <entry valign="top">Corrective Action</entry></row>
    </thead>
    <tbody><row><entry><indicator>ANTSKID</indicator<br/>
    EIC that is called up when I select "Indicates" entry
    <e-i-c gi="entry" context="*" thead&quot;<br="/>gitype="element">
    <charlist inherit="0" charsubsetref="center" bold&quot;=">
    </charlist>
    </e-i-c>
    <charsubset charsubsetid="center&lt;br"/><quadding quad="center" lastquad="lcenter">
    </charsubset>
    Seems pretty straight forward to me but for some resaon the "Resolved"
    view shows that center justification is in effect (what I expect), but the
    Print View version has left justified text.
    > Steve Thompson
    > +1(316)977-0515
    quadding won't work on an inline element. Try making the eic a "block" and see
    if that helps.
    You will have to confirm this with Arbortext Technical Support, but I think
    quadding coded in the FOSI is overridden by the horizontal alignment setting in
    Cell Table Properties. I think the problem is that the default selection is
    Left. There is no Inherit or Default choice for quadding in Table Properties.
    For example, if you code a font family in the FOSI for entry, it is used unless
    the Modify Cell Font Table Property specifies something other than Inherit for
    the font family. This choice overrides the FOSI. The same thing with table row
    breaking. It has a choice of Default, which means whatever is coded in the FOSI.
    Other row breaking settings override the FOSI setting.
    Again, please confirm this with Arbortext, and also please share what you learn.
    I'll put it in Essential FOSI.
    Thanks!
    Suzanne Napoleon
    www.FOSIexpert.com
    "WYSIWYG is last-century technology!"
    Hi Suzanne,
    I'm interested in this subject as well from the point of learning about
    FOSI, however we do have a working FOSI that centers the text in the
    title row. However, I'm not sure exactly how it works. This may well be
    outside the scope of the answer Dan is looking for. From the point of
    view of learning how the FOSI does what it does (I'm pretty much a noob
    with regard to this), we have an attribute of the element "entry" which
    is "center":
    Our table "entry" element has an "align" attribute of "center", the
    table markup looks like this:
    <table id="123456">
    <title>
    <english>A Simple Table</english>
    <french>A Simple Table</french>
    </title>
    <tgroup cols="3"><colspec colname="col1" colwidth="13.99pi"/"><colspec<br/>colname="col2" colwidth="13.99pi"/><colspec colname="col3"&lt;br"/>colwidth="13.99pi"/>
    <thead>
    <row>
    <entry align="center" valign="top">Etiam suscipit lorem </entry>
    </row>
    </thead>
    <tbody>
    <row>
    <entry>1</entry>
    <entry>Malesuada fames </entry>
    <entry>Suspendisse eget </entry>
    </row>
    <row>
    <entry>2</entry>
    </row>
    </tbody>
    </tgroup>
    </table>
    I could have the element "<text> Malesuada fames </text> within the
    <entry> element. The code of the table made me consider whether I should
    be looking for an attribute in the FOSI but I don't see one for
    align="center". I suppose what I'm doing is trying to follow the
    references backwards from the element entry. I took a look and in the
    FOSI and the table eics which matched elements are as follows:
    <e-i-c gi="table">
    <charlist inherit="1" charsubsetref="block"></charlist>
    </e-i-c>
    <e-i-c gi="text" context="entry">
    <charlist inherit="1"></charlist>
    </e-i-c>
    The <entry> element "charlist" is set to "1" so it inherits. So Looking
    further up the fosi closer to the beginning for "block" and "charlist" I
    note the following entries:
    <charsubset charsubsetid="block">
    <textbrk startln="1" endln="1"></charsubset>
    <charsubset charsubsetid="inherit">
    <quadding inherit="1">
    <highlt inherit="1"></charsubset>
    I note the "charsubsetid='inherit" quadding is set to "1" so it
    inherits, but I'm not quite sure how that relates to the following
    <docdesc> which also refers to "block" and "charlist":
    <docdesc>
    <leading inherit="0" lead="1.2em">
    <indent inherit="0" leftind="@" rightind="@" firstln="*">
    <quadding inherit="0" quad="left" lastquad="relative">
    <presp minimum="0pt" nominal="0pt" maximum="0pt" condit="discard"&lt;br"/>priority="none">
    <postsp minimum="0pt" nominal="0pt" maximum="0pt" condit="discard"&lt;br"/>priority="none">
    <keeps scope="col" keep="0" widowct="0" orphanct="0" next="0" prev="0">
    <textbrk startln="0" endln="0"></charlist>
    </docdesc>
    So in the <docdesc> the quadding in charlist is set to inherit="0". That
    means no. I take it that the charsubsetid of inherit, where the quadding
    is set to inherit for the <entry> element is over-riding the <docdesc>?
    Did I get lost somewhere? What part did the attribute "align='center"
    play if any? I did find some quadding charsubsetid entries in the FOSI:
    <charsubset charsubsetid="cquad">
    <quadding inherit="0" quad="center" lastquad="relative"></charsubset>
    <charsubset charsubsetid="lquad">
    <quadding inherit="0" quad="left" lastquad="relative"></charsubset>
    <charsubset charsubsetid="rquad">
    <quadding inherit="0" quad="right" lastquad="relative"></charsubset>
    Anyway, it would seem I have much to learn as I eventually want to add
    new elements to my DTD and create entries in the FOSI to output them.
    Greg
    J
    Hi Suzanne,
    That attribute had to do something. Digging a little further, when in
    Epic Editor if I choose format/modify element-in-context I find the
    element text in the context of entry is set to inherit missing
    categories. It has an Attribute Rule or:
    if element: attribute entry: align is center
    if element: attribute entry: halign is c
    I'll look in the FOSI with a text editor for these values.
    Greg
    J
    Wow, I got myself turned around J. Ok, the first set of e-i-c's I quoted
    were from the screen FOSI. There is a lot of code in the print FOSI. You
    may find this snippet useful, the e-i-c for the "text" element below in
    the context of entry is from the print FOSI:
    <e-i-c gi="text" context="entry" row=" tbody&quot;=">
    <charlist inherit="1" charsubsetref="block" hyphen-en&quot;="></charlist>
    <att logic="or">
    <specval attname="align" attloc="entry" attval="center">
    <specval attname="halign" attloc="entry" attval="c">
    <charsubset>
    </att>
    The elements english, french, and text are often used interchangeably
    within the element entry. I note that "quadding inherit" is set to "0"
    (not to inherit) and the quad is set to center. At this stage, I'm out
    of my depth, as the specval attname="align" is still used with a value
    of center. I'm not sure how that is interpreted to turn out centered
    text in printed copy. More reading to do I guess. I've got the Arbortext
    FOSI Reference,AE 5.4 F000 of June 2009, so I guess it's a good place to
    start. J
    Greg
    And there's your problem. At least, as far as any 'header' row is concerned. The context is "entry row tbody", which in SGML/XML path parlance is tbody/row/entry/text. You need an e-i-c for thead/row/entry/text, which would be context="entry row thead" (or more simply context="* thead"), if you want to format the content in a header row.
    HTH,
    Steve Thompson
    +1(316)977-0515
