Jan 26, 2011 4:34 PM UTC
FOSI editing
Never mind. I found it in preferences. There is an option to "Remove Arbortext PIs on save".
    Jan 26, 2011 5:00 PM UTC
    Thanks Ed. Saved me some money you did.
    Jan 26, 2011 9:49 PM UTC
    Would you recommend a simple DTD or schema for a simple book like the operators manual in your car? Probably a good Arbortext one out there I just need to stumble across. Trying a commercial book and am trying to get away from the overly-complex Army-type.
    Eventually it would be imported into an S1000D system but there is neither the time nor the budget to worry about that now.
    John T. Jarrett CDT
    Senior Tech Writer, Integrated Logistics Support,Land & Armaments/Global Tactical Systems
    T832.673.2147 | M 832.363.7234 | F 832.673.2376| x1147 | -
    BAE Systems, 5000 I-10 West, Sealy, Texas USA 77474
    www.baesystems.com
    Jan 26, 2011 10:08 PM UTC
    When I need a document to "play" with in Editor, I usually go with the
    Arbortext-supplied version of Docbook. However, for a project with a
    little more scope, particularly one intended for the sort of modular
    maintenance approach espoused by S1000D, I think it would be only
    moderately more work, initially, to start a DITA bookmap and create
    concept, reference and task topics as needed. These topics should
    readily map to S1000D data modules, while the bookmap would be
    translated to whatever form your S1000D system uses to organize
    modules into a print publication.
    -Brandon Smiley Happy
    On Wed, Jan 26, 2011 at 3:49 PM, Jarrett, John T (US SSA)
    > Thanks,
    > John T. Jarrett CDT
    > www.baesystems.com
    Jan 26, 2011 10:41 PM UTC
    If you have 5.4, you might try the SMA (DITA specialization). It's got
    samples that might be reasonable starting points.
    Jan 26, 2011 10:44 PM UTC
    I agree. Going along with DITA is closer to the S1000D design. It has some
    quirks of its own and features you would probably want to stay away from
    if you intend to go to S1000D. The good thing about it is the DITA Open
    Toolkit. With that you can complie your output to PDF or HTML help without
    having to buy anything.
    Not sure what tools you have from PTC, but if you have PE or digital media
    publisher you could get similar outputs from that as well. OT will have
    xsl/xslt stylesheets that you can tweak directly, the PTC products I
    belive use Styler stylesheets.
    ..dan
    >> Thanks,
    >> John T. Jarrett CDT
    >> www.baesystems.com
    Jan 27, 2011 3:16 AM UTC
    For the record, these PIs are used by the style panels interface. They are
    inserted when the FOSI is opened in the FOSI style panels interface and then
    saved in either interface. PIs are inserted by the FOSI tagged
    interface.
    Suzanne Napoleon
    "WYSIWYG is last-century technology!"
    www.FOSIexpert.com
    Jan 27, 2011 4:48 PM UTC
    Is the automotive DTD from SAE apparently formerly called J2008 and/or T2008 dead? References in Google show it right up until 2004, then nothing. Not found under that name on their website, either.
    John T. Jarrett CDT
    Senior Tech Writer, Integrated Logistics Support, Land & Armaments/Global Tactical Systems
    T 832.673.2147 | M 832.363.7234 | F 832.673.2376 | x1147 | -<">mailto:->
    www.baesystems.com
    Jan 27, 2011 5:18 PM UTC
    Hi John,
    I think I have a copy. I'll dig it out and send it to you when I find it.
    Liz
    On Thu, Jan 27, 2011 at 7:48 AM, Jarrett, John T (US SSA)
    > John T. Jarrett CDT
    > Tactical Systems
    > www.baesystems.com
