bfriesen
18-Opal
Nov 16, 2018 4:03 PM UTC
publishing a pdf with svgs
We are currently thinking about switching from CGMS to SVGS to get our publish times down. When I created my test pdf using svgs, the items outside the bounding box in isodraw also show up in the pdf. Our editors use big models and show what they need to in the bounding box in Isodraw leaving the rest of the model outside the bounding box. With CGM's there is a isoconvert.prf file, in the editor install location, where I can specify to use the CGM VDC Extent (change 0 to 1). Then editor outputs only what is in the bounding box. PTC support says there is no optoin like this for svgs. What do other users do when using svgs?
Bryon
AnugaAnswer
Apr 11, 2019 2:01 PM UTC
Hey! I recommend the use of SVG! We use it a lot here, both for printing material but the exact same material for web. And that's why we converted all of out EPS to SVG.
However, we use Adobe Illustrator and Inkscape to make our SVG files and then add them to our material, via Arbotext and some APIs.
Anuga1-VisitorAnswer
