7-Bedrock
Feb 21, 2025 7:51 PM UTC
Publishing error messages
</Record><Record date="Fri Feb 21 13:44:38 2025" millis="1740167078"
severity="fatal" suppress="0">
<Level>FATAL ERROR</Level><Message>Operation terminated.</Message>
</Record>
How do you relate this to a particular line or section of your document?
Detailed errors mention line numbers. Is there a way to see line numbers in Arbortext Editor?
I am using version 8.2.
7-Bedrock
Mar 11, 2025 5:02 PM UTC
Accepted solution
Feb 22, 2025 3:52 PM UTC
Take a look:
bfriesen
18-Opal
Feb 26, 2025 1:19 PM UTC
Does this happen with every publish or just once?
Bryon
7-Bedrock
Feb 26, 2025 2:07 PM UTC
Thanks for your reply. I have corrected the problem. In doing a cut and paste from another document, I did not properly format a section.
BTW, Editor error messages could be more detailed, to point to where the problem is.
bfriesen
18-Opal
Feb 26, 2025 3:14 PM UTC
I agree that the error messages are not always. helpful in trying to figure out what the issue is. Another tool you could try is the completeness check, found under the tools menu. It should flag improper structure in your document.
Bryon
KW_110253347-BedrockAuthorAnswer
7-Bedrock
Accepted solution
