Aug 3, 2011 7:08 PM UTC
running command line executable and capturing stdout
Hey everybody,
Is there a way from either ACL or Javascript to run a command line executable and capture the output from stdout? The ACL function system() just returns a success or failure status code. (I'm running Windows.)
For a broader picture, I want to do some HTTP PUT and DELETEs using curl, and capture the resulting status code that is output to stdout. So if there's a reasonably sane way to do low-level HTTP stuff more natively in Arbortext, I'm open to that too.
James
    18-Opal
    Aug 3, 2011 7:22 PM UTC
    Hi James-
    The basic pattern for doing this is to redirect stdout to a file when
    you run the command, and then read in the resulting text file and parse
    it as needed. I developed a utility function to do this a while back,
    here's the gist of it:
    function windows_command(command) {
    # executes the given command and returns any text sent to stdout
    result = system("cmd /C " . command . " > $home\epicoutput.txt",1);
    if (result != 0) { return "*** command failed ***" }
    else {
    $output = ";
    $outputfile = open("$home\epicoutput.txt");
    while (getline($outputfile,$line)!=0) {
    $output = $output . " " . $line;
    close($outputfile);
    system("cmd /C del $home\epicoutput.txt",1);
    return $output;
    HTH
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    jsulak1-VisitorAuthor
    Aug 3, 2011 8:50 PM UTC
    Thanks, everyone. I was hoping to avoid the write to a file / read from a file loop, but I guess that's the only way to do it.
    -James
    18-Opal
    Aug 3, 2011 9:15 PM UTC
    If you *really* object to writing/reading a file, you might be able to
    set something up using Java where you redirect System.out to a
    java.io.StringWriter or something similar and use Runtime.exec(). But to
    be honest that seems like a lot more trouble than it's worth, unless
    there's some kind of high cost involved with writing and reading from
    the file system.
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    18-Opal
    Aug 4, 2011 4:36 PM UTC
    OK, so it was more trouble than it was worth, except that my curiosity
    got the better of me. Here's some JavaScript code that uses Java objects
    to get the job done without writing to/reading from any disk files:
    var rt = Packages.java.lang.Runtime.getRuntime();
    var pid = rt.exec("cmd /C dir C:\\Temp");
    var is = pid.getInputStream();
    var isr = Packages.java.io.InputStreamReader(is);
    var br = Packages.java.io.BufferedReader(isr);
    var line = br.readLine();
    var output = ";
    while (line != null) {
    output += line + "\n";
    Application.print(output);
    This is just static code to run a test case, but it works. Conversion to
    a general function is left as an exercise.
    Of course, you could also write it in pure Java if you prefer that, or
    maybe even ACL using the various java_*() functions.
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    Aug 4, 2011 10:16 PM UTC
    Very cool, thanks for sharing Clay!
    Aug 5, 2011 3:24 PM UTC
    Very nice, Clay. Just be careful crossing the street...
