Styler 5.3: Cross-reference number style resolution for nested steps
Adepters:
Can Styler 5.3 resolve number styles (e.g., 1., a., etc.) for nested
steps in a procedure when cross-referencing? It seems that no matter
which level the id occurs, Styler only resolves the number of the
highest level nested step in the cross-reference.
Given the following markup:
<step1>
<para>This is step 1.</para>
<step2 id="stp-020">
<para>This is step a.</para>
</step2>
<step2>
<para>This is step b.</para>
<step1>
<para>Go back and do step <xref idref="stp-020"/"></para>
I'd like the following output:
1. This is step 1.
a. This is step a.
b. This is step b.
2. Go back and do step a.
But Styler generates:
1. This is step 1.
a. This is step a.
b. This is step b.
2. Go back and do step 1.
Why? Is there a limitation in Styler which prohibits it from resolving
nested step id references using the number style associated with that
level? What's funny is that double-clicking the generated text in the
xref repositions the cursor to the correct location (step2).
John Sillari
Dayton T. Brown, Inc.
jsillari@dtb.com
    Hi, John...
    I can't readily explain why you're seeing this result. With the
    default stylersheet on a Docbook document in 5.3, I created a
    procedure similar to yours and the cross reference showed as "a",
    rather than "1".
    Can you give us some more detail about the Gentext settings for your
    xref and step2 elements, including the numbering details for step2?
    -Brandon 🙂
