6-Contributor
Baseline Information Not Accessible in Test Run View
There is no provision to surface or reference Baseline details directly within the Test Run window, making traceability and version comparison cumbersome
Emeritus
Hi ​@RJ_14168288,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Vivek N
Community Moderation Team
Brian Kampling
Hi ​@RJ_14168288 could you provide more context around how you are using baselines in your process and why you need to see that data in the test run? Everyone does things a little differently and I have not heard this need before so it would help if I had more context relating to your configuration and process.
Brian Kampling | Source Allies Inc. | Systems Engineering Consultant
