Dec 22, 2025 8:04 AM UTC
In V2.2.1.3, the Review Hub has a wrong base url
Due to some reasons, our Codebeamer has separate internal and external network access addresses. After our Codebeamer was upgraded to V2.2.1.3, when we open the Review Hub, it consistently points to the internal network address and cannot adapt according to the browser's domain name. In the previous version V2.1.0.0, this issue did not exist. How can we make the Review Hub's address change dynamically?
tymorrowAnswer
Jan 5, 2026 4:28 PM UTC
Hi @JR_12222956 ,
Codebeamer 2.2 and onward feature a newly upgraded ReviewHub which leverages the Angular UI previously used for Codebeamer-X. Behind the scenes, this new UI references different functions and settings of the Codebeamer server than the legacy version.
In the 2.2 series specifically, the URL is actually set under System Admin -> Outgoing Email Connection. Please review the following article:
https://www.ptc.com/en/support/article/CS423575
Please let us know if this helps.
Thank you,
Tyler
PTC Technical Support
Catalina
Community Manager
Jan 5, 2026 4:02 PM UTC
Hi @JR_12222956
Thank you for your question.
Best regards,
Catalina | PTC Community Manager
tymorrow12-AmethystAnswer
Hi @JR_12222956 ,
Thank you,
Tyler
Emeritus
Jan 6, 2026 10:21 AM UTC
Hello @JR_12222956,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
