6-Contributor
Inability to Extract & Re-run Failed Test Cases
There is no built-in mechanism to filter out failed test cases from an existing test set and automatically generate a new test run for those failures.
Emeritus
Hi ​@RJ_14168288,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Vivek N
Community Moderation Team
Brian Kampling
Hi ​@RJ_14168288 Are you looking for assistance on a workaround or wanting to submit an enhancement request? If it is the latter, you can go here: https://community.ptc.com/codebeamer-ideas-401 to place enhancement requests. If it is the former, could you provide some additional context around what you are wanting help with?
Brian Kampling | Source Allies Inc. | Systems Engineering Consultant
