6-Contributor
Non-Configurable State Transitions in Test Run Reviews
The Test Run Review workflow follows a fixed process, offering no flexibility to customize state transitions to align with project-specific review governance.
Emeritus
Hi ​@RJ_14168288,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Vivek N
Community Moderation Team
Glenda_SAI
8-Gravel
Hi RJ! You might want to consider posting this in the Codebeamer Ideas board with a bit more detail. Things I might suggest thinking about are
  • if there is room for flexibility in the review process (or what the true goal of the review governance is)
  • if the true goal is visibility within the review process and how you would like to see things within review process (reports, views, or a kanban style board, etc)
Sometimes we think we are solving one problem with governance, and it helps to think through what the governance solves first, and how we intend the oversight to solve the problem. Good luck!
