6-Contributor
Suspect Flag Not Triggered on Test Specification Updates
When a linked Test Protocol or Test Specification is modified, the system fails to raise a suspect flag during execution, increasing the risk of running outdated test scenarios
Emeritus
Hi ​@RJ_14168288,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Vivek N
Community Moderation Team
Brian Kampling
Hi ​@RJ_14168288 could you provide more information about the tracker configurations with some screen shots showing the field settings for the fields that contain the changes you were expecting to trigger a suspect flag?
Brian Kampling | Source Allies Inc. | Systems Engineering Consultant
