6-Contributor
Test Runs Are Immutable Post-Review
Reviewers are unable to make edits or corrections to a Test Run based on review feedback, restricting iterative quality control within the execution cycle
Emeritus
Hi ​@RJ_14168288,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Vivek N
Community Moderation Team
Glenda_SAI
8-Gravel
Could you help us understand what you are trying to solve with this?
The test runs are designed to be immutable - this way you have a record of exactly how each run went.
If there is some feedback given that necessitates an iterative change, you would start a new test run if needed. This way you could compare the two runs and see the result of the feedback being implemented.
