Jan 17, 2012 4:09 PM UTC
3GB Switch Summary
3GB Switch Summary
    wfalco16-PearlAuthor
    Jan 17, 2012 6:00 PM UTC
    Here is a good supplement just in:
    Adding RAM is completely unrelated to the /3gb boot switch on 32-bit
    Windows. Many people incorrectly assume that the /3gb boot switch lets
    Windows use the installed RAM more efficiently.
    If you’ve never had Pro/E crash because it tried to access more than 2GB
    memory, then you don’t need the /3gb boot switch. This switch controls
    how much virtual address space each process can address.
    Virtual address space and RAM are not the same. A process’ virtual
    address space exists both in RAM and on the hard disk (page file). The
    Windows memory manager handles swapping memory pages to / from the disk
    so that any memory pages required by the CPU are loaded into RAM.
    So you can see that using or not using the /3GB switch has no effect on
    how Windows uses the installed RAM.
    Jan 17, 2012 6:15 PM UTC
    Another:
    Another good thing to know is how much memory ProE as an application is
    using.
    This TPI shows you how to use perfmon to determine exactly how much
    memory ProE is using.
