Apr 1, 2008 4:05 AM UTC
Animations
Hi Gurus,
Does anyone know how an animation can be converted from a mpeg to an avi? if so, is high resoluton possible?
thanks,
Paul DeLong
    Apr 1, 2008 1:38 PM UTC
    Paul,
    just google for "mpeg to avi" and you will find tons of free converters.
    D
    Jan 28, 2013 4:43 PM UTC
    Guru's,
    Hi there all we have a user who is creating animations (not got
    much experience with these) and he is having an issue with this bombing
    out whilst saving and rendering as an .avi file.
    does anyone have any type of guidelines to creating animation ie, how many
    frames to base it on and which settings to use, which they would be
    willing to share?.
    I am guessing that these are pretty much based on what is the spec of the
    machine (ours 4GB ram) but any sort of guidelines or standard setting
    would be helpful.
    We are using Creo 2.0 M020
    Many thanks
    Colin Down
    Mechanical Design Engineer
    Email: -
    Tel: +44 1305 208503
    The information in this e-mail and any attachments transmitted with it are provided in commercial confidence for the intended recipient(s). If you have received this e-mail in error, please notify the Postmaster by e-mail at -. Any views or opinions expressed are solely those of the author and do not necessarily represent those of DEK.
    For local company specific legal information for your country or region and any local contact information for DEK, please refer to:
    Jan 30, 2013 11:54 PM UTC
    Hi Colin...
    I have a good bit of experience with animations. I might be able to lend some advice. First, your frame rate really depends upon what you're trying to do with your final output. The frame rate for video is 30 FPS but you can cut that down to 24 FPS (which is the frame rate for film). This will reduce your frame count and your final file size.
    Even with the frame rate set lower, you might still have a problem getting the AVI to render. In this case, my best advice is to chunk the animation into pieces rather than trying to render one large monolithic file. Create multiple smaller animations (or render the animation in small sections) and then stitch them back together later. In the video industry this is called "fixing it in post". You'll also be able to gauge quality using the smaller animations and adjust accordingly.
    Do you know what settings your animator is trying to use? If so, having those to look at might help with a diagnosis.
    One final note... if you have access to Creo View licenses with the animation option, you can create some very nice animations using this product. If you're trying to animate mechanisms or simulate real-world motion then the animation package inside Creo is the way to go. Personally I try to stay away from that Creo animation package unless I absolutely have to use it. I use Creo View for most of my animation work but I am lucky to work for an employer that has the necessary licenses.
    Let me know what animation settings your user is working with and I'll give you my feedback if I think I can improve on them.
    Best regards,
    -Brian
    Brian K. Martin
    Sr. Mechanical/Application Engineer
    SGT, Inc. under contract to
    NASA Goddard Space Flight Center
    301.286.0059 (NASA Office)
    443.421.2532 (Cell)
    Follow me on Twitter @CreoHelp<">https://twitter.com/CreoHelp>
    Follow me on PTC Community<">http://communities.ptc.com/index.jspa>
