Can you add ACME Standard holes in Creo
Is there a way to add additional standards for hole in Creo? We have UNC, UNF and ISO out of the box but we use many ACME standards.
Thanks in advance for any input.
"Too many people walk around like Clark Kent, because they don't realize they can Fly like Superman"
    Several people responded that I can create a .hol file and place in the hole folder.
    So now my questions is...... What does a .hol file contain? Is there some kind of format on how you enter the hole information?
    Can someone provide an example?
    Thanks again.
    The best example is the existing unc.hol, unf.hol or iso.hol file in the <pro_loadpoint>\text\hole folder. I had created one for npt threads at one time. The file name is limited to 7 characters, so acm.hol could be your Acme thread file name.
    Thank you,
    Ben H. Loosli
    USEC, INC.
    PTC/Users are amazing. Thanks for the guidence from everyone and the files shared. 😉
    Ben
    7 chatacters total? Including the dot and the hol extension? Even DOS 1.0 had longer file names than that. It's bad enought that model names are still limited to 31 characters plus extension and that spaces are not allowed but 7? Unbelievable. That part of the code must be written on an Intel 4004.
    Damian
    If you got a working ACME hole file, care to share it?
    In Reply to Ben Loosli:
    Thank you,
    Ben H. Loosli
    USEC, INC.
    I don't know where the value 7 comes from. I have one with 15 that Pro/E reads. It's not one I have implemented for everyone. It's only a test file. But Pro/E shows it.
    Steve G
    They may have changed since Wildfire2. I named a file NPTF.hol and it wouldn't show until I renamed it to NPT.hol.
    Thank you,
    Ben H. Loosli
    USEC, INC.
    This is in WF4. I just tried a file with 30 characters including the 4 character extension (.hol). It showed up just fine.
    When you open the file you have to make sure you put the name of the file (or anything you want I guess) for the THREAD_SERIES header information:
    THREAD_SERIES INC_MFG_wFormat_Data_12345
    Steve G
    David,
    We don't have any made yet. I just found out how to get them in there thanks to the feedback from everyone here. Now I need to mess with the .hol file and figure out how to create one for ACME.
    If anyone else is willing to share at least one example of an ACME hole file, it would be appreciated by everyone.
    In Reply to David Gallup:
    Ben
    Damian
    Thank you,
    Ben H. Loosli
    USEC, INC.
    OK,
    Some of you submitted some .hol file examples and I greatly appreciate it. So how do I read it? I am not talking about how to open it because I used Word Pad just fine, but how do you actually read the file? I can't figure out what all the numbers relate too. Diameter, lenght, etc.
    The top section is fairly simple but the bottom section is like Matrix code. See below.
    TABLE_DATAPRO_VERSION 24THREAD_SERIES UNCCLASS 2BTABLE_UNITS inchDEPTH_RATIO 1.22CALLOUT_FORMAT &Screw_Size &Thread_Series-&Thread_Class <ctrl-a>x<ctrl-b> &Thread_Depth /<ctrl-a>w<ctrl-b> <ctrl-a>n<ctrl-b>&CSINK_DIAMETER[.2] X &CSINK_ANGLE[.0]<ctrl-a>$<ctrl-b>
    THREAD_DATAFASTENER_ID BASIC_DIAM THREAD TAP_DR TAP_DEC PERCENT_THREAD CLEAR_DR_CLOSE CLOSE_DEC CLEAR_DR_FREE FREE_DEC CLEAR_DR_MED MED_DEC CBOREDIAM CBOREDEPTH CSINKDIAM CSINKANGLE BOTCSINKDIAM BOTCSINKANGLE#1-64 0.073 64 #53 0.0595 81% #48 0.0760 #46 0.0810 0 0 0.1563 0.073 0.085 90 0.085 90#2-56 0.086 56 #50 0.0700 62% 3/32 0.094 #36 0.1070 0 0 0.1875 0.086 0.10 90 0.10 90#4-40 0.112 40 #43 0.0890 65% 1/8 0.125 #29 0.136 0 0 0.2188 0.112 0.12 90 0.12 90#6-32 0.138 36 #36 0.1065 71% #23 0.154 #18 0.170 0 0 0.2813 0.138 0.15 90 0.15 90#8-32 0.164 32 #29 0.1360 62% #15 0.180 #10 0.194 0 0 0.3125 0.164 0.17 90 0.17 90
    Turn off word wrap.
    [cid:image001.png@01CDD942.7BE16390]
