Nov 4, 2014 10:35 PM UTC
create flat pattn. then fold/bend?
What I have is a bushing from a customer with slots and holes in it. the holes and slots are dimensioned in the "unfolded" detail view of the bushing. I was wondering (being new to Creo) if there was a way to model the flat view and then "wrap" it"?
Thanks In advance.
Scott
    Nov 5, 2014 7:33 PM UTC
    Interesting. I see some things I have to question, but you are trying to figure out the angle at which the two hole features are created. Normally, that would be specified. Also the key feature for closure doesn't look interlocking but it does look like it should in the flat pattern on the right, but not on the left. Is there an allowable gap?
    You may not have all the information you need. I would think there is a finished OD or ID somewhere. I would begin with that size cylinder; determine the proper K or Y value of the material for that size radius; unfold and add features; then bend back. Some features may fail on a bend back so test this often. Sheetmetal parts do not like thinning but I think it can handle countersink holes well enough. Not sure about the chamfers either. If a feature fails at the sheetmetal level, you could consider placing it in an assembly and finishing the part with assembly cuts where applicable if needed.
    I am not sure what is to be done post-bend, but those features are certainly possible at an assembly level depending on the shop details you need.
    Nov 5, 2014 12:58 AM UTC
    You can create bends in specified locations, yes.
    Be sure to know what the customer used as a bend factor.
    You can set either a K-factor or a Y-factor.
    The bend radius too is critical in creating an exact copy.
    Nov 5, 2014 1:07 PM UTC
    it is a bushing so the start would have to meet the end of the flat pattn.
    Nov 5, 2014 6:55 PM UTC
    I guess 'd have to see it. Are you talking about a flanged bushing that is extruded from a disk with a hole in it?
